Results 1 to 2 of 2
  1. #1
    Join Date
    Jun 2009
    Location
    miamisburg, ohio, usa
    Posts
    1
    Default how to replace a 85 hp evinrud
    how to replace a 85 hp evinrude impeller
  2. #2
    Join Date
    May 2008
    Location
    Kent, the garden of England, UK
    Posts
    1,200
    Default Basically it is usually just a
    Basically it is usually just a question of dropping the gear unit off the get to the pump but models vary in how you will have to disconnect the shift rod.
    If you told us the year and/or model number someone may be able to give you some detail.
    A manual is advisable
Similar Threads
  1. How do i replace impeller on a 1985 70 hp Evinrude
    By wassajet in forum Johnson Evinrude Outboard Forum
    Last Post: 12-20-2010, 12:51 PM
  2. Replace impeller or wait
    By mercforme in forum Mercury Mariner Outboard Archive
    Last Post: 10-17-2009, 04:30 PM
  3. Replace impeller
    By gordy in forum Johnson Evinrude Outboard Archive
    Last Post: 02-08-2008, 10:07 AM
  4. Need to replace impeller
    By hbbutler in forum Mercruiser Sterndrive Archive
    Last Post: 10-29-2007, 05:18 PM
  5. Impeller replace
    By Roy H. Wyatt in forum Archive 2003-2007
    Last Post: 05-19-2004, 09:54 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
