"Hi, Graham! I've got a co
"Hi, Graham! I've got a couple of questions about a 1990, 115 Merc }I just bought. (1) Engine was laid up almost a year. Wouldn't idle but top end speed seemed ok. I brought it home and ran it on a hose I found squeezing the bulb increased low AND high end. No apparent damage i.e. tight, overtemp, etc... If a carb or carbs are faulty, is there any possiblity of having damaged it? Is the oil injection system still lubricating the engine if it's starved for fuel? At what point is the oil injected? (2) I replaced impeller but it takes 3 or 4 minutes for water to pee out of the tattle-tale. Comes out of prop and foot ok then pees. Water temp is fine. How long should it take to pee? (3) Does this motor run only on the top 2 cylinders at idle? (4) How should jacking plate be adjusted for maximum performance? I know this is a mouthful but I've got a manuel on order but haven't received it yet. Again, thanks VERY much for all that your team does for so many! David"
