Results 1 to 3 of 3
  1. #1
    Join Date
    Jun 2009
    Location
    New Prague, MN, United States
    Posts
    2
    Default "After the last outing I had w
    "After the last outing I had with this motor, the power tilt/trim seemed very sluggish in lifting the engine. When I got home and reviewed the manual, it didn't say how to maintain or check the fluid level, it just said to contact the dealer.
    How do you check the fluid levels and add ATF (Dextron II)?"
  2. #2
    Join Date
    Jun 2009
    Location
    united kingdom
    Posts
    86
    Default "iv a yamaha 80hp workshop man
    "iv a yamaha 80hp workshop manual,
    to check the fluid level tilt the motor up and engage the tilt lock lever,
    open the bolt on he top of the t/t reservior ,
    the fluid should be level with the bottom of the bolt hole if not add some fluid,
    when you put the bolt back in run the tilt and trim up and down it should purge any air for out for you.
    hope this helps you out."
  3. #3
    Join Date
    Jun 2009
    Location
    Posts
    2
    Default Thank You very much. I'll
    Thank You very much. I'll check it out this weekend. The motor has run fantastic for the 8 years I have had it.
Similar Threads
  1. 2000 90hp Tilt/Trim Issues
    By darlington_john in forum Honda Outboard Forum
    Last Post: 11-13-2010, 12:47 AM
  2. Trim Tilt maintenance 1989 5.0
    By neversummer in forum Mercruiser Sterndrive Forum
    Last Post: 05-19-2010, 04:47 PM
  3. Yamaha How do you tilt with tilt Trim not working
    By bigbuilder in forum Yamaha Outboard Archive
    Last Post: 12-10-2007, 07:41 PM
  4. 2000 75hp split tilt cylinder
    By bubtrauma in forum Mercury Mariner Outboard Archive
    Last Post: 08-31-2007, 09:31 AM
  5. Evinrude 2000 200HP Trim Tilt operation
    By andy in forum Johnson Evinrude Outboard Archive
    Last Post: 10-17-2006, 03:15 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
