Results 1 to 3 of 3
  1. #1
    Join Date
    Mar 2009
    Location
    Reading, PA, USA
    Posts
    7
    Default I need a new trim sending unit
    I need a new trim sending unit. No one locally sells OMC parts. Where can I get one? Or do I need to get a whole new guage/sender assembly?
  2. #2
    Default "What's wrong with the old
    "What's wrong with the old one? Mine was "froze up" and not working, I soaked it with PB Blaster and worked it back and forth a while and got it free and working again. I understand that the senders are almost impossible to find, but I tried fixing mine before looking so I don't know."
  3. #3
    Join Date
    Jul 2006
    Location
    Keswick, Ontario, Canada
    Posts
    1,847
    Default "You can check the sender with
    "You can check the sender with an ohm meter. Behind the engine at the transom the sender cable comes through near the steering arm. It's a 2 wire black cable with a connector back there. Disconnect it and attach both leads of the meter to the 2 pins (sender side) you can then lift the drive and manually move the sender arm from one end of travel to the other while checking the meter, it should be 0 ohms at one end and go up to approx 200 at the other end.
    No idea where you can get them now, seems like they have been non-existent for a year now."
Similar Threads
  1. trim sending unit
    By scorpion in forum Volvo Penta Gas Engine Forum
    Last Post: 05-26-2010, 11:00 PM
  2. Omc cobra tilt indicator sending unit
    By camperfind in forum OMC Sterndrive and Inboard Forum
    Last Post: 10-05-2009, 04:03 PM
  3. OMC oil pressure guage sending unit
    By D. wright in forum OMC Sterndrive and Inboard Archive
    Last Post: 06-13-2008, 05:09 PM
  4. Trim sending unit
    By sae267839 in forum OMC Sterndrive and Inboard Archive
    Last Post: 09-08-2006, 09:05 PM
  5. Trim Gauge Sending Unit
    By billyg in forum Outboard motors archive 2000-2004
    Last Post: 09-14-2001, 11:52 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
