I read a lot of posts and ther
I read a lot of posts and there is a lot of really smart folks out there. I hope someone has come across my issue. My port engine starts cold and hot without issue. In fact they run great! However on the port engine if I shut down and don't restart within 45 minutes the restart is a toss up. The engine kicks over right away and runs rough for 10 seconds then stalls. On the second attempt it will run a bit better. At this point sometimes it will start RPM hunting if it does this I am in good shap I know it will stay running if not it will stall and eventually I get a crank no start condition until the engine cools to about 125 degrees. Then it will start as if cold perfect. As a test I even gave some thottle during rough start in which the engines responded. Brought RPM to about 2000 for 10 seconds and then engine stalled straight from there. So no throttle control changes what eventually ends up being a stall to a crank no start condition. I can't afford to trouble shoot changing everything for no reason. I am hoping some smart fellow boater might have experienced the same problem. Thanks in advance.
