Results 1 to 4 of 4
  1. #1
    Default "my motor is a 1994 yamaha 150
    "my motor is a 1994 yamaha 150 saltwater series. the fuel gauge failed and i ran out of gas. after refilling, the motor would not get over 4200 rpm at full throttle, made 5500 rpm an hour before. Changed water seperator which was really dirty, checked engine mounted filter which was very clear. Also checked compression, which are all six cylinders low at 105 psi--all exactly the same. I would have thought compression would go unequally between the cylinders, unless something was preventing all six cylinders from making 125-130 psi. Any body have any idea what else can keep the cylinders from getting full compression?
    I am no expert at this---appreciate any help. thanks."
  2. #2
    Join Date
    Feb 2009
    perth, wa, Australia
    Default "Battery condition will effect
    "Battery condition will effect the readings, so will a different compression gauge...however i wouldnt be worried about the compression figs they are fine."
  3. #3
    Join Date
    May 2009
    punta gorda, florida, usa
    Default try running a shock does of ri
    try running a shock does of ringfree thru it
  4. #4
    Join Date
    May 2001
    Default "Running out of gas can cause
    "Running out of gas can cause problems, especially if you are running at high rpms when it happens.
    V-6 engines can be very vulnerable when this happens, depending on exactly how the fuel is distributed. A vertical rail, feeding stacked carbs, will usually cause the top carb to run out of fuel first. The engine can continue to run, and damage can result.
    Fuel injected engines probably would not experience this."
Similar Threads
  1. 1987 Johnson 150 hp RPM reduced with Cowling on
    By Katyjinny in forum Johnson Evinrude Outboard Forum
    Last Post: 11-03-2010, 08:12 PM
  2. 1998 200 hp OceanPro reduced power
    By interd0g in forum Johnson Evinrude Outboard Forum
    Last Post: 03-26-2010, 09:35 PM
  3. Causes of Reduced Oil Pressure
    By knuckle47 in forum Crusader Marine Engine Forum
    Last Post: 10-08-2009, 06:52 AM
  4. Reduced Power after Rebuild
    By swhandyman in forum OMC Sterndrive and Inboard Forum
    Last Post: 09-03-2009, 10:49 AM
  5. 50 220hp Reduced Revs and Top Speed
    By mrgrumpy in forum Mercruiser Sterndrive Archive
    Last Post: 08-28-2007, 02:49 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
