Click for Honda Manuals, Parts and Model Guides!
Results 1 to 3 of 3
  1. #1
    Default Can anyone tell me what the co
    Can anyone tell me what the compression should be on a 2003 BF90? I'm considering buying a used boat with twin BF90's and want to be sure the engines are in good shape. Thanks.
  2. #2
    Join Date
    Feb 2009
    Location
    , NT, Australia
    Posts
    34
    Default G'day Matt. My w/shop manu
    G'day Matt. My w/shop manual only gives a ratio of 8.8-1. No actual psi rating. Hope this helps.
  3. #3
    Join Date
    Mar 2008
    Location
    , Florida,
    Posts
    279
    Default "The most important factor is
    "The most important factor is the difference between the readings from cylinders. Closer to equal, the better and 10% or more indicates trouble.
    Best done with the engine warm, throttle wide open, all spark plugs removed and ignition disabled (pull the safety laynard and may need in forward gear to achieve full throttle).
    Some Yamaha's give different pressure target values between upper and lower cylinders, but this is unusual and Jon would have mentioned it, if it were in his Honda manual.
    If you see a 'low' reading cylinder, squirt some oil in and do it again, if improved you know it's a ring issue and if not, a valve issue.
    A better test is a pressure test where a special calibrated fitting applies 80 psi test pressure and a gauge measures that +/- 70 psi or so is maintained. This is done with the piston locked at top dead center on the power stroke. With this method you can hear the air escaping through valve or crankcase."
Similar Threads
  1. Noise in BF90
    By buster_1 in forum Honda Outboard Forum
    Last Post: 03-10-2010, 07:20 PM
  2. 2003 150 hp VMax compression numbers
    By jampilot in forum Yamaha Outboard Forum
    Last Post: 01-02-2010, 10:05 PM
  3. 2003 honda 130 hp Compression
    By flipper1 in forum Honda Outboard Forum
    Last Post: 09-10-2009, 12:04 AM
  4. Anyone do a water pump replacement on a 2003 BF90
    By ggb3 in forum Honda Outboard Archive
    Last Post: 06-16-2008, 03:51 PM
  5. 2003 BF90 Water Pressure Issues
    By otdrzman in forum Honda Outboard Archive
    Last Post: 03-14-2008, 02:57 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
