1969 85hp chrysler outboard runs at 13 speed
littlesleep
"I just bought this boat. it w
"I just bought this boat. it was going 35mph no problem then the motor lost all power and shut off.. I restarted it just fine, but now it will only go 7 or 8 mph at full throttle. any ideas?????"
Compression test. Is the temp
Compression test. Is the temp sensitive paint on the exhaust cover all brown? Water pump?
Run a spark test.
Check your timing advance lever and make sure the link didn't fall off. Same with throttle linkage.
