Results 1 to 11 of 11
  1. #1
    Default My new cdi 3wire rectifier cam
    My new cdi 3wire rectifier came today and i noticed the red wire was offset. Where on two other rectifiers it was in the middle.Should this be a concern?One more thing is i tested the new rectifier with an ohm meter. Black to ground then red to each wire. The needle went about 3 quarters to the right on each one.Then i reversed the test. Black to yellow etc.the needle then moved slightly to the right before dropping back to the left.I thought the needle was not supposed to move at all.The test was done with the recitfer connected on the motor and no battery.
  2. #2
    Default Can someone help.I can try to
    Can someone help.I can try to explain my question better.
  3. #3
    Join Date
    May 2008
    Location
    Kent, the garden of England, UK
    Posts
    1,200
    Default Test it disconnected. Not fa
    Not familiar with the colours on that one otherwise could go through the testing with you.
    Red is positive I guess but which is negative ... ground?
    yellow and black the connections to the stator?
  4. #4
    Default Thanks Two yellow wires one re
    Thanks Two yellow wires one red .I'm going now to pull it completely off and retest. Its sierra 18-5708 for 1973 135hp evinrude not cdi.
  5. #5
    Default That was it. I'm only gett
    That was it. I'm only getting a one way reading now.I didn't know that the rectifier must have all wires disconnected to ohms test it.But still a little concern about the red wire not comming out in between the two yellows wires.I have rectifiers here and on both the red wire are in between the yellows.
  6. #6
    Join Date
    Nov 2005
    Location
    lockhart, texas, US
    Posts
    5,812
    Default "hook it up,...as normal...it
    "hook it up,...as normal...it makes no diff,how they r potted,in the rectifier.."
  7. #7
    Join Date
    Nov 2005
    Location
    lockhart, texas, US
    Posts
    5,812
    Default "u state,..u have a CDI-- and
    "u state,..u have a CDI-- and a sierra???"
  8. #8
    Join Date
    Feb 2001
    Location
    Central West Florida
    Posts
    14,308
    Default "As you've discovered, the
    "As you've discovered, the rectifier must be disconnected from all other wiring in order to be tested.
    (Small Rectifier Test)
    (J. Reeves)
    Remove the rectifier wires from the terminal block. Using a ohm meter, connect the black lead of the ohm meter to the rectifier base (ground), then one by one, connect the red lead of the ohm meter to the yellow, yellow/gray, then the red wire (some rectifiers may also have a fourth yellow/blue wire. If so connect to that also). Now, reverse the ohm meter leads and check those same wires again. You should get a reading in one direction, and none at all in the other direction.
    Now, connect the black lead of the ohm meter to the red wire. One by one, connect the red lead of the ohm meter to the yellow, yellow/gray, and if present, the yellow/blue wire. Then reverse the leads, checking the wires again. Once more, you should get a reading in one direction and none in the other.
    Note that the reading obtained from the red rectifier wire will be lower then what is obtained from the other wires.
    Any deviation from the "Reading", "No Reading" as above indicates a faulty rectifier. Note that a rectifier will not tolerate reverse polarity. Simply touching the battery with the cables in the reverse order or hooking up a battery charger backwards will blow the diodes in the rectifier assy immediately.
    Thousands of parts in my remaining stock. Not able to list them all. Let me know what you need and I'll look it up for you. Visit my eBay store at:
    http://stores.ebay.com/Evinrude-John...tc?refid=store"
    We occasionally have questions. If you fail to answer, it may affect ours.
  9. #9
    Join Date
    Nov 2005
    Location
    lockhart, texas, US
    Posts
    5,812
    Default "he has purchased,a new one,fr
    "he has purchased,a new one,fr what i understand,...he should not have to do any testing...hook it up..."
  10. #10
    Default JW i just bought a multi meter
    JW i just bought a multi meter i wanted see how it works on things.The rectifier is sierra not cdi my bad.I tested a rectifier i had lying around it tested good.You guys got me doing things i was afraid to try before.Thanks for being there.I know you answer the same questions over and over but they are new to me. Equal thanks to all.
  11. #11
    Join Date
    Apr 2006
    Location
    , Langkawi, Malaysia
    Posts
    5,750
    Default "It is a 'pot hole' wh
    "It is a 'pot hole' when testing with an analog (dial) tester and diodes like You have in the rectifier.
    All diodes have a 'leak', and the amps provided by the tester is a bit low. That is why You may experience the reaction from the needle as You describe. Ohm testing the way recommended might trick You slightly.
    Don't worry, just hook it up.
    As a rule, disconnect battery from engine when not using and battery drain from leakage may be avoided. The diode leakage is mainly the difference between expensive and 'cheap' rectifiers, but has no effect when running."
Similar Threads
  1. Installing a voltage regulater with a three wire rectifier
    By flyrod in forum Johnson Evinrude Outboard Archive
    Last Post: 06-05-2009, 01:03 PM
  2. 1986 Evinrude CE20TECDC Rectifier
    By evin1 in forum Johnson Evinrude Outboard Archive
    Last Post: 08-14-2007, 09:02 AM
  3. Ground wire for 1991 Force 90 rectifier
    By John Carrol in forum Chrysler Force Outboard Archive
    Last Post: 11-13-2006, 09:31 PM
  4. 88 evinrude voltage rectifier regulator
    By papyson in forum Johnson Evinrude Outboard Archive
    Last Post: 10-19-2006, 08:28 AM
  5. 79 evinrude raticle rectifier i think
    By Steve Yager in forum Johnson Evinrude Outboard Forum
    Last Post: 10-12-2002, 01:20 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
