mustangturbo50
"ok so last year my boat ran g
"ok so last year my boat ran great last year , so i got it out this year and found that i had left a little water in the exhaust manifold so it cracked it a little, not bad but a little, so i had it fixed and took it out the water and it started and reved up great in neutral , i put it in gear and started to go out of the harbor and it just wont go over 5 mph, if i go more than 1/4 or 1/2 throttle it bogs down and just wont go. i took the old gas out and put new in, checked the oil for water and everything looks great, so i dont now think anything is cracked anywhere. The odd thing is that if i let off the throttle and put it in neutral it revs right up no hesitation no nuthing, just revs up liek it is supposed to.
i check compression in all the cylinders and it is 92 lbs all the way accross , all the same.
if anyone has any advise let me know
im leaning more tords a carb issue but i could be wrong. i think it is just a coinsidence that it happens to be running like this since the manifold froze"
