Results 1 to 5 of 5
  1. #1
    Join Date
    Jun 2009
    Location
    Enniskillen, Ontario, Canada
    Posts
    17
    Default "Hi guys,I'm trying to set
    "Hi guys,I'm trying to set my total timing but I only seem to be getting 12deg of advance ...spec is 8deg at idle so I only get 20 at 3000 rpm on the water(not on muffs)....I thought maybe srpings were too stiff so I checked on plane while a friend brough to 4000 rpm...no more advence. A few years ago I did try to put electronic ignition in & MAY have put new springs in....I'm thinking that maybe they are actually too soft & using up some of my advance even at idle? Anyone have advance timing curve spec for this setup? I have ordered replacement springs for now & set initial timing at 12 so I can get 24 at 3000 but think I am missing some performance here...
    I am using timing tape on ballancer with reg timing light- works nice
    Thanks,
    Paul"
  2. #2
    Join Date
    Mar 2009
    Location
    Lowell, MA
    Posts
    1,217
    Default "definately, on the right trac
    "definately, on the right track, yea too loose a spring and you'll have too much at idle, too tight and it wont come in till your up high in the revs.. sounds like they might be light. Timing tape if def a good thing.
    The holes on the weights or weight bushings could be worn to.. or even the weight posts. the advance shaft could also be binding not allowing it to advance fully."
  3. #3
    Join Date
    Jun 2009
    Location
    Posts
    17
    Default "Thanks Brian, I didnt expext
    "Thanks Brian, I didnt expext wear since there is only about 500 hrs on this dist...I will double check when the springs come in..I was considering a light brake lube but these may be best left dry?
    Other consideration- Anyone know if my ignition module provides any advance- or is it just for shift assist??
    Thanks,
    Paul"
  4. #4
    Join Date
    Jun 2009
    Location
    Posts
    17
    Default "Ok, got new springs from Durh
    "Ok, got new springs from Durham Marine Ontario- Winston just gave them to me- great guy! Worked perfect, I'm getting full advance again!
    Thanks for the feedback!
    Paul"
  5. #5
    Join Date
    Mar 2009
    Location
    Lowell, MA
    Posts
    1,217
    Default "Excellant Paul !! Make him so
    "Excellant Paul !! Make him some cookies, or buy him a beer or buy him lunch..
    Nice !!"
Similar Threads
  1. Mallory Advance Curve Change Kit Question
    By Jim Munley in forum Crusader Marine Engine Forum
    Last Post: 08-17-2010, 09:34 AM
  2. AQ170 advance curve graph
    By dariosergio in forum Volvo Penta Gas Engine Forum
    Last Post: 09-27-2009, 06:33 PM
  3. Advance timing
    By jsnookman02 in forum Mercruiser Sterndrive Archive
    Last Post: 04-07-2008, 01:17 PM
  4. Timing curve for a LM318 1974
    By Captain Randy in forum Chrysler Inboard and Sterndrive Archive
    Last Post: 06-23-2007, 11:54 PM
  5. 74 Gi too much timing advance
    By one_track_mind in forum Volvo Penta Gas Archive
    Last Post: 09-18-2006, 09:58 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
