Results 1 to 3 of 3
  1. #1
    Join Date
    Jun 2009
    Location
    cc, tx, us
    Posts
    2
    Default "I have a 2008 yam 70 hp 2 str
    "I have a 2008 yam 70 hp 2 stroke with under 40 hrs. just began to notice oil leaking from the lower unit out of the prop, can anyone tell me why this is"
  2. #2
    Join Date
    Apr 2009
    Location
    Greenville, South Carolina, USA
    Posts
    131
    Default the exhaust goes out through t
    the exhaust goes out through the prop so you may see some black oiliness there but if the oil is clean and clear it may be a lower unit seal leaking. remove your prop and drain and refill your lower unit with fresh oil. that way you can see if water is leaking into or out of that seal. good luck!
  3. #3
    Join Date
    Dec 2008
    Location
    Victoria, B.C., Canada
    Posts
    645
    Default "a small amount is nothing to
    "a small amount is nothing to worry about, as Robert says just exhaust residue"
Similar Threads
  1. Oil leaking around prop
    By bowpb07 in forum Johnson Evinrude Outboard Archive
    Last Post: 07-02-2009, 07:32 PM
  2. Oil Leaking bad from Prop
    By marineman43 in forum Johnson Evinrude Outboard Archive
    Last Post: 06-24-2009, 12:06 PM
  3. 1998 250 EFI Leaking Oil at prop
    By brian_grady in forum Mercury Mariner Outboard Archive
    Last Post: 04-15-2009, 06:19 PM
  4. Leaking oil behind prop help
    By mikepags in forum Mercruiser Sterndrive Archive
    Last Post: 02-22-2008, 11:57 AM
  5. Prop leaking oil
    By jofa928 in forum Mercury Mariner Outboard Archive
    Last Post: 07-14-2007, 04:57 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
