Click for Honda Manuals, Parts and Model Guides!
Results 1 to 2 of 2
  1. #1
    Default "This is my 1st post And woul
    And would like any thoughts on my problem
    I have a 90hp Honda with gear problems the dogs grate in reverse as if itís out of adjustment. If you remove the remote controls and shift the gears manually it appears to be OK. I removed the bearing carrier and the dogs look OK.I temporarily fitted an ultraflex control box and it was fine.
    I have fitted a new Honda remote control and the reverse gear grates. If I adjust the reverse then I lose the forward gear. And vice versa.
    Regards,
    Neilp"
  2. #2
    Join Date
    Jun 2009
    Location
    , NC,
    Posts
    4
    Default "To be honest with you, i thin
    "To be honest with you, i think they all do it. Ours has done that ever since we bought it brand new. I think you just have to be firm when you shift it into reverse and don't let it sit on that grinding position."
Similar Threads
  1. 90hp Honda
    By Navyguy20042003 in forum Honda Outboard Forum
    Last Post: 08-02-2010, 11:14 PM
  2. Honda 90hp
    By richard39 in forum Honda Outboard Forum
    Last Post: 04-15-2010, 09:50 PM
  3. 2002 90HP Honda
    By mbz in forum Honda Outboard Forum
    Last Post: 09-03-2009, 08:22 AM
  4. Rebuilding gearshift and throttle box
    By cathyandjames in forum Johnson Evinrude Outboard Archive
    Last Post: 06-08-2008, 10:56 PM
  5. Honda 90hp engine issues
    By wakeboard mike in forum Outboard motors archive 2000-2004
    Last Post: 04-22-2003, 10:06 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
