Click for Honda Manuals, Parts and Model Guides!
Results 1 to 6 of 6
  1. #1
    Join Date
    Jun 2009
    Location
    United States
    Posts
    1
    Default How do you remove the silencer
    How do you remove the silencer?
    I've removed the two bolts but it still remains attached. Are there hidden bolts?
  2. #2
    Join Date
    Jun 2009
    Location
    , NC,
    Posts
    4
    Default "I am having the same problem.
    "I am having the same problem. There are 3 bolts that i found. One is on the bottom. Even with three removed, something is still holding it in. Is there something i'm missing?"
  3. #3
    Default the silencer can't be remo
    the silencer can't be removed without taking the carbs and intake manifold with it
    there is a bolt at the back up against the engine
  4. #4
    Join Date
    Jun 2009
    Location
    , NC,
    Posts
    4
    Default Is intake manifold removal dif
    Is intake manifold removal difficult? Also can i re-use gaskets on intake manifold and carbs or do i need to replace them all?
  5. #5
    Default "no the intake manifold remova
    "no the intake manifold removal is not difficult
    and no you can not reuse gasket on the manifold or carbs at least I couldn't
    I take it you are doing a carb rebuild, if so
    you need to get a shop manual
    and you need a vaccum gauge to sync the carbs after your done"
  6. #6
    Join Date
    Jun 2009
    Location
    , NC,
    Posts
    4
    Default "Update : I got everything rem
    "Update : I got everything removed, took the carbs apart and cleaned them (counting number of turns on idle mixture screw) and re-assembled. Runs better than ever. Thanks for all your input and help blackfish."
Similar Threads
  1. Honda BF90A alarms
    By iftia in forum Honda Outboard Forum
    Last Post: 10-05-2009, 11:07 PM
  2. Honda bf90a ptt
    By muzza191 in forum Honda Outboard Forum
    Last Post: 05-23-2009, 09:16 AM
  3. Honda BF90A
    By captrob in forum Honda Outboard Archive
    Last Post: 03-23-2009, 03:43 AM
  4. Used Honda BF90A Advice
    By edrock13 in forum Honda Outboard Archive
    Last Post: 02-22-2009, 06:59 PM
  5. Honda bf90a carb cleaning
    By Dave Cattrell in forum Honda Outboard Archive
    Last Post: 05-21-2008, 11:12 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
