Aq 125 distributor
mmarks00
i have a distributor apears th
i have a distributor apears the screw that holds down the condensor is stripped.could this cause loss of spark.
I think it can cause problems
I think it can cause problems related to poor grounding. It should be an easy fix.
Have a great day
Rob.
"Mike,
another suggestion i
"Mike,
another suggestion is to replace the points and condenser with an electronic solid state ignition. Pertronix makes part#2842 for your distributor and will eliminate the need to keep adjusting the points every couple of months.Electronic ignitions are about the cheapest upgrade to your boat and makes a world of difference ex:starts and idles 100% better, timing doesn't float and you never have to adjust it.set it and forget it!!!works great on my aq125"
