Vacume advance for a 188 grey
wndowhunt
anybody know where the vacume
anybody know where the vacume advance hooks to the carb or manifold on a 188 grey with twin side draft carbs
"If you have the carb setup of
"If you have the carb setup off the engine there should be a port under the carb manifold closest to the distrib. Not on the carb but the manifold that the carb is bolted to. The brass tube runs under the carb to the dist, under the dist and bends around back to the advance mech.
Dual carbs Graymarine
"The pictures were from the te
"The pictures were from the tech manual but there is nothing in there that I found for vacuum advance. I just looked at my own engine to see the routing that I had. V8C 225, same 327 AMC block.
Cal"
