Results 1 to 5 of 5
Thread: OMC Cobra
  1. #1
    Default "Hello, I have an 89 Bayliner,
    "Hello, I have an 89 Bayliner, 19', 5.0 ford with a OMC Cobra outdrive. It shifts into reverse whether I put it in drive or reverse. I have heard about some electrical mechanism. Any help with this problem would be greatly appreciated.
    Thanks"
  2. #2
    Join Date
    Jul 2006
    Location
    Keswick, Ontario, Canada
    Posts
    1,847
    Default "There is nothing electrical f
    "There is nothing electrical for the shifting on a Cobra. I would be checking inside your gearshift/throttle control first for a problem, the cable either gets pushed or pulled."
  3. #3
    Default "My 5.8 OMC just had electroni
    "My 5.8 OMC just had electronic ignition, dist cap, rotor and plugs replaced. I ran good before and I wanted to update and improve shifting. Runs fine at idle and high speed; 3000 and up. Problem is engine runs rough at 1200 rpm up to about 2800 rpm and almost cuts out sometimes. What should I check before changing coil and ignition wires?"
  4. #4
    Join Date
    Mar 2009
    Location
    Lowell, MA
    Posts
    1,217
    Default what type of carburator do you
    what type of carburator do you have ?
    Cutting out to you could be hesitation to me which means carb issue. but not usually in that range unless you have a 4bbl Rochester and theres a problem with the primary metering rods/circuit.
  5. #5
    Join Date
    Mar 2009
    Location
    Lowell, MA
    Posts
    1,217
    Default "oh if it is a 4bbl quadrajet,
    "oh if it is a 4bbl quadrajet, or not, you can tell its a fuel lean issue if you have someone drive and while in that range slowly close the choke butterfly, if it improves, your lean. if not then it's something else.
    Was the timing checked/adjusted with the ignition was changed? could be the mechanical advance isn't working right either."
Similar Threads
  1. 460 cobra jet 460 super cobra jet
    By bobby_wilson in forum Ford Interceptor Marine Engine Forum
    Last Post: 08-01-2009, 10:35 PM
  2. 23 ford cobra outdrive behind a 43 cobra
    By twister in forum OMC Sterndrive and Inboard Archive
    Last Post: 07-24-2006, 08:03 PM
  3. Omc cobra lower unit nightmarevolvo sx or king cobra swap
    By 91mariah50omc in forum OMC Sterndrive and Inboard Archive
    Last Post: 06-30-2006, 03:00 AM
  4. Swap King Cobra for a Cobra
    By Coleman Lauterbach in forum Archive 2003-2009
    Last Post: 06-01-2003, 09:35 AM
  5. 1993 OMC KING COBRA vs 1990 OMC COBRA
    By Steve Beasley in forum OMC Sterndrive and Inboard Archive
    Last Post: 12-31-1969, 07:00 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
