Tuneup carb plugs and new big block wires
drphil
"had fresh water impeller key
"had fresh water impeller key slip and motor got hot. Blown head gasket, upon removal found riser leaking water into back cylinder, rust in maninfold. Had heads rebuilt, resurfaced new riser and carbs vatted and rebuilt. Have put 1 inch riser on carbs and new plug wires big block chevy. Any special ideas for the break in, should I use any top cylinder lubricant to help break in the heads? Spray like marvel mystery oil into carb after motor is running and warmed up? Lots of work and don't want some friends of mine giving me grief that I should have hired it done. I can do about as well as the grease monkey, i hope."
"Buy some Lucas ZDDP additive,
"Buy some Lucas ZDDP additive, put half a quart in, then fire it up. Keep checking for leaks or other stuff and, if all is well, let it run until its fully warmed up. Then go over all of the exhaust system bolts and re tighten them.
Good luck!
Jeff"
