"Hello,
I am new to this fo
"Hello,
I am new to this forum and I've run into a situation that I thought I might run by you.
I have a 1986 AQ145B engine that ran fine last year, but when I started it this year, I hear tapping coming from the #4 cyl and the oil pressure is around 30lbs at idle even when cold. I haven't changed the oil yet from last year, but it is full and is clean/clear on the dipstick. I have run the engine for 20+ mins and the tapping doesn't go away, but is diminished when I rev the engine (the oil pressure also increases to 50 - 60lb range). Since there seems to be a tie to the oil pressure, I suspect the oil pump is not able to get sufficient oil to the cam/valves over the rear cylinder? I haven't done a compression test yet. I know in old cars, sometimes "sludge" develops at the bottom of the oil pan and it can block some of the oil pump intake. Any thoughts or help would be appreciated. Thanks."
I am new to this fo
"Hello,
