"Well today was the day to tac
"Well today was the day to tackle this job. I was not a piece of cake. The first attempt to remove the bolt on the harmonic damper resulted in a snapped 3/8" socket extention. Had to go get a 1/2" socket and extention. Holding the damper was done with the use of a crowbar held between the water pump housing and the damper by one person while the other, with the use of a 20" pipe over the handle of the ratchet provide the needed leverage. Next came off the pulley and belts. But now the really hard part...pulling the damper/harmonic balancer off the shaft. Yes, I remembered that important hint to remove the big washer. I borrowed a so called "universal" puller from Autozone but it didn't have the correct bolts to attach it to the damper, so we used the bolts for the pulley. Boy did this require a lot of torque and once again had to use the crowbar to keep the shaft from turning. Had it out about 3/8 of an inch when suddenly something gave and the socket wrench was turning much easier. I thought it had finally broken free bu damn, the threads stripped on the large center bolt of the puller" Off to a hardware store to get some longer bolts in order to use threads further up that big bolt. Once the new longer bolts were in place we were finally able to get the damper off.
Removing the seal was next and was not too difficult..just had to use a screwdriver and hammer to bang the seal in towards the center and then pry it out. Cleaned the area up, applied a light coat of gasket sealer to the outside edge of the new seal and installed it using a makeshift tool made of a 3" OD black pipe coupling with a plug in one end. Installed the sleeve on the damper using a block of wood and hammer...went on nice a straight. Installing the damper went well using a combination of another Autozone installer tool and then a small sledge hammer to drive it all the way on, using that 3" coupling again. Reinstalled the center bolt and washers, pulley, and belts. Fired up the engine...and HOORAY! Let it run for about 20 minutes and no oil leak.
I could not have done it without the great advice and suggestions from Mark, Dave, and others on this forum. THANK YOU ALL!
Sorry for the long post but maybe thisi will help someone else in the future.
Erich"
