queen_elvis
"I am in the process of instal
"I am in the process of installing a rebuilt Volvo MD2B, replacing an existing engine with an almost identical model. One difference, however, is that my old engine had a fresh-water pump installed whereas the new one does not.
I want to add the fresh water pump to the new one, and am trying to figure out how to drive it. On the old engine, someone had installed a pulley on the hand-start connection shaft, and this was used to drive the fresh-water pump. It seems that I would have to remove the hand-start shaft and put the pulley on there. But that seems like it might be a lot of effort, and may well be beyond my skill level with marine diesels.
So instead, I am considering putting a second pulley on my flywheel. The one pulley on there right now drives my alternator. Is it a viable option to add the second pulley to drive the water pump?
There are 4 bolts attaching my pulley to the flywheel, and I think I could add the second pulley by adding some spacers (probably about an inch or more long!) to position the second pulley well beyond the existing one. And adapter of some type would be necessary, too. Has anyone attempted such a set-up? And was it successful?
And where might I be able to buy a pulley? And is anyone likely to sell an adapter to allow me to attach this pulley to the flywheel?
Oh, and of course, is there a better way to do this?
Thanks a lot."
Thanks a lot."
