Results 1 to 9 of 9
  1. #1
    Default did the same thing last year f
    did the same thing last year first time out. I added gas to the tank and no problem since
  2. #2
    Default "it quits like the key is turn
    "it quits like the key is turned off, no sputter like fuel shortage any ideas?"
  3. #3
    Join Date
    Aug 2006
    Location
    SW Ohio, USA
    Posts
    10,396
    Default Fuel stabilizer used in the fa
    Fuel stabilizer used in the fall? EFI or carbed? When was the last time it was tuned up and fuel filters changed?
    Fix minor things (replace wear items for preventative maintenance.) that cause major problems before they break.
  4. #4
    Default "2002 5.0 litre carbed, runs f
    "2002 5.0 litre carbed, runs for a short time then quits. new filter last fall, fogged and stabl in the gas. it quits like the key is turned off. is there a saftey sensor that shuts down the engine for some reason?"
  5. #5
    Join Date
    Aug 2006
    Location
    SW Ohio, USA
    Posts
    10,396
    Default Do you have a strong spark at
    Do you have a strong spark at the plugs when it quits? Does the carb accellerator pump quirt fuel when the throttle is pushed quickly in neutral?
  6. #6
    Default "is it a tks? if so check the
    "is it a tks? if so check the oil pressure switch, I believe it will shut down the fuel pump if its going bad."
  7. #7
    Default "fuel squirts, I can hear it w
    "fuel squirts, I can hear it with the engine compartment is open. Where is the oil pressure switch? I don't know what tws is either, but a couple of years ago I had an alarm going off, I think for the outdrive oil resevour, I filled it and that stopped. There is no alarm now though"
  8. #8
    Join Date
    Nov 2002
    Location
    Mullica Hill, New Jersey, United States
    Posts
    1,810
    Default "Like Guy stated, are you losi
    "Like Guy stated, are you losing spark? You need to determine what is stopping, fuel or ignition. It could be the OP switch, it could also be the starter solenoid."
  9. #9
    Default "thanks for the advice. I cha
    "thanks for the advice. I changed the fuel filter again from the sierra I was given to a mercury. That did it, runs great."
Similar Threads
  1. MC 43L V6 starts fine then dies after 5%7e10 seconds
    By bhuffman in forum Mercruiser Sterndrive Archive
    Last Post: 09-13-2009, 07:40 PM
  2. BF15 Starts runs for 2 3 seconds then dies
    By pmains in forum Honda Outboard Archive
    Last Post: 02-04-2009, 10:37 PM
  3. 350 MAG starts nice dies in 23 seconds
    By captn_jack_1 in forum Mercruiser Sterndrive Archive
    Last Post: 12-16-2008, 07:41 PM
  4. 43 merc starts then dies after a few seconds
    By Jo Rockman in forum Mercruiser Sterndrive Archive
    Last Post: 07-27-2008, 01:01 PM
  5. 470 quits abruptly
    By Bob Buschert in forum Mercruiser Sterndrive Archive
    Last Post: 07-19-2006, 12:35 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
