Oil Filter removeal on a DF 40 outboardFour stroke
redman91
How do you remove the oil filt
How do you remove the oil filter on a DF 40. What do you have to take-off to get the filter off/out? Thanks for the info...Redman91
I have a DF 50 and I have to t
I have a DF 50 and I have to take the lower cowl off on the dipstick side of the engine. It's about 8 bolts. You will also have to disconnect the tilt trim switch on the cowl as well but that is just a simple clip on clip off plug. Also where all the cables go into the engine...you will just have to separtate that but it is part of the 8 or so bolts I mentioned above. If you need more help post up and I will get my Zuzuki manual that covers both the DF 40 and 50.
