"1984 90 HP E90TLCR. Starts an
"1984 90 HP E90TLCR. Starts and runs fine at idle, will run as long as you want at 2000 - 2500 rpm using fast idle lever, but will die when put in gear if given any throttle. Carbs have been rebuilt and are clean, replaced vro pump with new fuel only pump. (pump is for '83 90 hp, it bolts right on over the pulse hole, Sierra p/n 18-7352). Also new fuel line connectors, all hose clamps and fuel connections are tight. Squeeze the bulb to pressurize system, no fuel leaks anywhere, bulb stays hard. Engine seems to run ok at low or high idle under no load but dies in gear. Any suggestions? Thanks..."
