Results 1 to 5 of 5
  1. #1
    Join Date
    Oct 2006
    Location
    virginia beach, va,
    Posts
    57
    Default "I just can't get enough t
    "I just can't get enough time in reading all the great tip provided here.Thanks! I am going to replace my gimbal bearing and seal and I see the manual shows the notches on the bearing going on towards the inside. I am sure the old one was the opposite and seemed to work. What is the difference in operation of the bearing if it was backwards? Which way does the seal face, lip in or out? Does the bellows reinstall on the bell housing first and then the transom? Are there ever concerns with the grommet at the intake pipe leakingwhen replacing the intake hose? I know it took a lot of wiggling to get it off and I'd hate to start over if I meesed it up. It looks like it is tough to get to on the inside, any thoughts?"
  2. #2
    Join Date
    Jun 2006
    Location
    Spotswood, NJ, USA
    Posts
    3,242
    Default "notches aft if you prefer to
    "notches aft if you prefer to replace only the bearing next time.There was a time that you could by aftermarket bearings ,but no more.
    If you mean the inner grease seal behind the bearing I`d go lips to the bearing not the motor
    bellows are glued on the housing first then the transom end
    the inlet tube is almost never removed to replace just the hose from the gimbal to transom.If you mean getting loose from removing or installing the new hose, No."
  3. #3
    Join Date
    Oct 2006
    Location
    virginia beach, va,
    Posts
    57
    Default "I had a hole in the bellows a
    "I had a hole in the bellows and when I removed it I found oil or liquified grease amounting to about a 1/3 cups worth. I'm trying to guess where it came from, the outdrive or somewhere else. I haven't checked the level on the outdrive yet but how likely is it from the outdrive if it was only immeresed in the saltwater a couple of times before I noticed the leaking bellows."
  4. #4
    Join Date
    Jul 2008
    Location
    Northboro, Ma, USA
    Posts
    4,270
    Default "It most likely came from the
    "It most likely came from the ujoints bieng greased annually as they should be with enough grease to squeeze some out and also the gimbal itself if it has a grease fitting at 4 oclock it should be overgreased and that grease ends up in the bellows
    If you suspect the outdrive, drian the gearlube and pressure check to 15 psi and it should hold for 2 minutes with no leak down."
    Jack
    Northborough Ma
    Helping others sometimes with an attitude....haha..
  5. #5
    Default Mercstuff.com sells just the g
    Mercstuff.com sells just the gimbel bearing that if you have a late bearing with two grooves in it you just turn the bearing 90 degrees and pull it out. Replace the new bearing in reverse order. So easy. To replace the seal the whole bearing mount must be removed. Instructions are on there website.
Similar Threads
  1. Gimbal bearing
    By mrwalleye in forum Mercruiser Sterndrive Forum
    Last Post: 05-26-2010, 08:37 PM
  2. Gimbal bearing
    Last Post: 05-26-2010, 02:09 PM
  3. Gimbal Bearing replacement on mercruiser
    By russsb in forum Mercruiser Sterndrive Archive
    Last Post: 07-25-2008, 09:59 AM
  4. DPSM Gimbal Bearing Replacement
    By petesim in forum Volvo Penta Gas Archive
    Last Post: 10-01-2007, 12:37 AM
  5. 1986 gimbal bearing replacement
    By dawgs in forum Mercruiser Sterndrive Archive
    Last Post: 03-14-2007, 07:52 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
