Results 1 to 5 of 5
  1. #1
    Join Date
    May 2009
    Location
    Prince George, British Columbia, Canada
    Posts
    2
    Default Would anyone be able to tell m
    Would anyone be able to tell me what the fuel/oil ratio would be for a 1979 Sears Canada Gamefisher 15 outboard?
  2. #2
    Join Date
    May 2007
    Location
    Inverary, Ontario, Canada - The Great White North Eh!
    Posts
    9,114
    Default "Don that will be an Eska buil
    "Don that will be an Eska built model with a Tecumseh twin cylinder powerhead - basically just a lawnmower engine.
    The Tecumseh engine is a model 383A (should you ever need parts, that number at a small engine place will help you out).
    You can mix this at 24:1 with regular 2 cycle motor oil (such as used with lawnmowers/chainsaws) - don't use outboard TCW3 oil it will burn up too quickly - meant for water cooled powerheads.
    If you find it blows alot of smoke at 24:1 you try moving that ratio a bit but would not go leaner than 40:1 at the absolute max."
    Graham
    A "professional" is someone who gets paid for their work - it doesn't necessarily mean they are good at it :)
  3. #3
    Join Date
    May 2009
    Location
    Quartzsite, Az, usa
    Posts
    489
    Default "That motor was actually water
    "That motor was actually water cooled and will run "TCW". The 24/1 mix is right as this engine had a drilled crankshaft instead of reed valves and depended on good main bearings and oil viscosity to run right. It's delicate cdi bolted under the flywheel with 2 white coils on the cylinder head was susceptible to heat damage --so a good water pump was important. These coils could not be disconnected and spin the engine W/O ruining the CDI. When I worked on them, I would solder the slide on connectors so they would not come off.
    Sorry to get so wordy, but these were a real unusual motor with lots of faults."
  4. #4
    Join Date
    May 2007
    Location
    Posts
    9,114
    Default "Thanks William, forgot that t
    "Thanks William, forgot that the 15 and some 9.9's were water cooled - usually answering questions about the smaller singles..."
    Graham
  5. #5
    Join Date
    May 2009
    Location
    Quartzsite, Az, usa
    Posts
    489
    Default "If it makes you feel any bett
    "If it makes you feel any better, they did make a 9.9 single aircooled under the Sea King banner. Was a wards motor and had the one and only full shift lower unit in the whole production line. Also came in an identical looking 7.5."
Similar Threads
  1. 99 sears gamefisher
    By paul chris smith in forum Gamefisher Outboards
    Last Post: 05-17-2009, 09:10 PM
  2. Sears gamefisher 30
    By ted1199 in forum Gamefisher Outboards
    Last Post: 08-26-2008, 05:29 AM
  3. Gas cap for Sears Gamefisher 35
    By drumsandkeys in forum Gamefisher Outboards
    Last Post: 07-09-2008, 08:50 AM
  4. SEARS GAMEFISHER
    By Wendell F. Colen in forum Archive 2003-2009
    Last Post: 05-21-2006, 10:28 AM
  5. Sears Gamefisher
    By Don Martin in forum Outboard motors archive 2000-2004
    Last Post: 05-28-2002, 03:08 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
