43 seems to be running hot
wblazer
"Hi Guys,
Just brought my 198
"Hi Guys,
Just brought my 1986 4.3 Alpha one back to life.
Running on the muffs temp is at 200. Does that seem wright. Last season in the river i don't think it was that high. Is it because running on muffs? Thanks for your help."
"BT Doctur
Impeller was new l
"BT Doctur
Impeller was new last season, did not put on many hours.I did change exhaust boots last season.My guess risers are original.Do they need to be changed ?"
Get a laser thermal temp. gun
Get a laser thermal temp. gun and find out the location of the heat buildup. Turn the hose pressure to max.
"Thanks Guy,I will do as you s
"Thanks Guy,I will do as you suggest. Did notice a lot of rust when changing the thermostat, may have a blockage."
"also if you use those inline
"also if you use those inline water shut off peices, they have a nasty happy of restricting the flow."
