"350cid 270hp 1989 Crusader FW
"350cid 270hp 1989 Crusader FWC. Just replaced risers, elbows, and thermostat (160) removed and flushed manifolds. Gauge on the dash says 160. Used IR temp gun to get following measurements, most taken on the hoses. Just in case the drawing doesn't show up too good. Port manifold 213, starboard 195. Top Center of the heat exchanger 192. Should I worry if the temp gauge (and the thermostat housing) reads 160? Just a little concerned that the heat exchanger is hitting 192. Any Ideas????
temps
