Results 1 to 7 of 7
    Nov 2008
    Saratoga Springs, New York,
    11
    Default "I have a 1960 Sea-Skiff w/ a
    "I have a 1960 Sea-Skiff w/ a 283. Just had the carb (Carter WCFB) totally rebuilt. It runs great when you get it going, but it tends to stall when shifting into fwd/rev. Any ideas?
    Thanks!"
    Feb 2006
    Cleveland, OH,
    33
    Default Need to know what the idle is
    Need to know what the idle is set at? Normally it would be around 500 rpm in gear or 600 to 700 in neutral with paragon trans. I checked my 283 f and m manuals and neither mention timing or idle which is sort of strange.
    Jun 2008
    Island Heights, NJ,
    3,313
    Default "RE: "I checked my 283 f a
    "RE: "I checked my 283 f and m manuals and neither mention timing "
    My 283FLV manual says to use a timing light to set timing to the mark, i.e. the "crankshaft pully timing mark directly in line with the ignition timing indicator". It also says... Idle, in gear, 500 RPM."
    Capt Bob
    1969 23ft ChrisCraft Lancer
    Merc 5.7L 260HP/ Volvo 280
    Apr 2009
    Erie, Michigan, USA
    44
    Default The "283" F or H model
    The "283" F or H model with the WCFB or the Rochester 4bbl should be set at 650-700 RPM's for the idle speed. my old service man. for the 283 H says 650 to 700 with the Paragon hydraulic or manual reverse gear.
    Fred Durbin
    Nov 2008
    11
    Default Thanks all! I think my timing
    Thanks all! I think my timing is set at around 500 @ idle. I will check it this weekend.
  6. #6
    Default Re: Stalls when shifting
    Good morning. I am a first time Chris Craft owner. I have a 1964 CC SuperSport with a 283. When I put in reverse engine stalls out unless I quickly increase rpms. Engine cuts out each time engine clutches into reverse at low speed. Any ideas.
    thanks
    Chris
  7. #7
    Mar 2009
    Portland, Oregon,
    11,996
    You have posted to a thread that was started back in April 2009.
    It would be best if you were to start a new and fresh thread!
    Portland, Oregon
  1. Mercury 75 stalls when shifting into gear
    By sat1425 in forum Mercury Mariner Outboard Archive
    Last Post: 10-05-2008, 07:15 PM
  2. New Yamaha 150 Stalls when shifting
    By ksgoldman in forum Yamaha Outboard Archive
    Last Post: 07-03-2008, 04:06 PM
  3. Mercruiser 470 stalls when shifting only when hot
    By N Shmyr in forum Mercruiser Sterndrive Archive
    Last Post: 07-16-2007, 12:05 AM
  4. Mercruiser stalls when shifting wonbt restart
    By Richard Mudarri in forum Mercruiser Sterndrive Archive
    Last Post: 06-05-2007, 09:28 AM
  5. Mercruiser stalls when shifting into gear
    By Greg Wirick in forum Mercruiser Sterndrive Archive
    Last Post: 12-31-1969, 07:00 PM
