Water pump wonbt pickup ear muffs attached to water hose
bigdade11
2003 merc cruiser wont pick-up
2003 merc cruiser wont pick-up ear muffs but when I try it in the water it runs great. Any pointers!
"OK Frank
Here is the deal
"OK Frank
Here is the deal
when you ask a question here FROM now on.
Post the year, motor size, outdrive (alpha gen I or II or bravo ot trs. and anything else that may help us with your issue.
We cant read your mind and we cant see your boat
So that bieng said REPOST a correct question with any and all info you can supply!"
"give some info on engine mode
"give some info on engine model and year, including outdrive. and also explain exactly what it's doing/not doing so these good folks can help, and trust me they will help.
welcome to the site, jeremiah"
Oh and by the way do you have
Oh and by the way do you have a water pump impeller attached to the front of your engine?
It should look like a second altenator or second power steering pump.
If so it gets its water from the bottom of the boat with a thru hull pick up.
