Cold cranking amps minimum
timeout
I'm trying to find out the
I'm trying to find out the minimum cold cranking amps required for my engines. They are Volvo 8.1 Gil-C's. I need to replace my batteries and want to make sure I equal or exceed the minimum amps required.
"I believe that Volvo specifie
"I believe that Volvo specifies a non-deep cycle battery, 12V, 650 CCA rating, 135 minute reserve capacity."
"Thanks for the response. The
"Thanks for the response. The boat was delivered to me new, with Gel-cell 31 series batteries; 1 for each engine. This seems to be over-kill. There is an additional 31 series battery that supports the house needs. I'm thinking I can get away with Gel 27's as engine batteries. The charger stays on all the time, and I'm going into the 7th season with the OEM batteries. I'm concerned that I may be pushing my luck and would like to replace them.
Thanks again....
Dave"
Why not replacing them with wh
Why not replacing them with whatever has worked well for you for 7 years (or equivalent)? Then you eliminate the guess.
