Click for Ford Lehman manuals!
Results 1 to 3 of 3
  1. #1
    Default "Hello, Yesterday we picked
    Yesterday we picked up our Grandbanks for the summer and we a lot of white smoke during full throttle ( port engine ). Might it be possilble that the cooling system needs to be cleaned? If so, any suggestions on how to do this the easy way?
    Kind regards,
  2. #2
    Join Date
    Aug 2009
    Daphne, Al,
    Default It probably is associated with
    It probably is associated with cooling. I had the same problem with my port engine on a GB. I rebuilt both raw water pumps and the problem went away. I did check the heat exchangers but there was any fouling. The impellers in the RW pumps were very bad.
  3. #3
    Join Date
    Aug 2009
    Hobart, Tasmania, Australia
    Default "G'Day, Dennis,
    "G'Day, Dennis,
    Need more info for a educated guess.
    1. Eng temp at time of smoke?
    2. What rpm @wot?
    3. Are you loosing any coolant?
    4. Has engine been over heated?
    5. Has coolant been allowed to freeze?
    6. Does engine start easy and idle SMOOTHLY?
    7. Does the eng exhaust beat sound even no miss? Which model.
    Cheers Shakey"
Similar Threads
    By Sea blue in forum Ford Lehman
    Last Post: 10-17-2015, 03:26 PM
  2. Ford Lehman SP 275
    By jejuda in forum Ford Lehman
    Last Post: 08-20-2013, 05:22 PM
  3. Replies: 2
    Last Post: 10-07-2010, 11:53 PM
  4. Ford lehman
    By paige in forum Ford Lehman
    Last Post: 09-12-2009, 07:39 AM
  5. Ford Lehman
    By gregggrundon in forum Ford Lehman
    Last Post: 11-16-2007, 01:25 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
