More details, please.
Jeff
You have a 26' with a single 318? Is your trans a 2:1? What is your pitch and diameter of your prop?
Yes; that boat should plane IF the motor is running properly. Either it is not, the prop is wrong, or the bottom is needing cleaning.
I suggest you put a timing light on it and see if you are getting full spark advance AND full retard; it's common for the advance mechanism in those distributors to stick. If they stick advanced--and someone times it that way--then you won't get full advane and the motor will be a dog at full throttle.
Jeff
Page 6:Jeff,
Bottom newly painted, timing has beem done t times but.i.dont know.that anyone was aware of what you were talking about. How can check mechanical advance manuelly? Id like to do that before i start prop shoping
