Click for Suzuki Manuals, Parts and Model Guides!
Results 1 to 4 of 4
  1. #1
    Join Date
    May 2009
    Location
    Monroe, La, United States
    Posts
    3
    Default Suzuki DT 40 (86) Powe
    Suzuki DT 40 (86) Power trim bleeds down when I raise it. It goes up fine and worked before I bought the boat. Now I raise it and it slowly goes back down over 1-2 minutes. Is there something easy I can check? I'm waiting on the repair manual I ordered.
  2. #2
    Join Date
    May 2009
    Location
    Posts
    3
    Default Any words of wisdom would be g
    Any words of wisdom would be great!!!!!
  3. #3
    Default I do not have my manual in fro
    I do not have my manual in front of me but it would be safe to say that the trim/tilt fluid is leaking by the seals internaly and the unit would need to be taken off and rebuilt. Is there any fluid leaking out? I had an issue with my DF 50 (2004) where I had fluid leaking out of the main seal. I still had warranty so I let the dealership fix it although the dealer said it was not a hard problem to replace the seal or remove the unit in general.
  4. #4
    Join Date
    May 2009
    Location
    Posts
    3
    Default So you are saying it sounds li
    So you are saying it sounds like the seal inside of the piston is leaking? I haven't seen any fluid leaking out.
Similar Threads
  1. Power trim bleeds off fast
    By chuck4907 in forum Johnson Evinrude Outboard Archive
    Last Post: 11-27-2008, 10:05 AM
  2. Suzuki DT55 Power trim problems
    By big_cliff in forum Suzuki Outboard Archive
    Last Post: 02-06-2008, 01:40 PM
  3. Motor wonbt raise on my power trim only lower
    By jeff schneidewend in forum Archive 2003-2009
    Last Post: 12-04-2003, 11:32 AM
  4. Power Reeds Air Bleeds Tuning and Other Tales
    By R. Wood in forum Outboard motors archive 2000-2004
    Last Post: 05-31-2002, 09:46 PM
  5. Power Reeds Air Bleeds Tuning and Other Tales
    Last Post: 05-30-2002, 07:29 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
