Float level
bw94
"I'm rebuilding the carbs,
"I'm rebuilding the carbs, do i have to set the float level, how do i remove the orifice plug, the one behind drain plug for the bowl. Thanks"
"Removing the orifice jet requ
"Removing the orifice jet requires a special screwdriver. You can clean it where it is with a piece of single strans steel wire.
(Carburetor Float Setting)
(J. Reeves)
With the carburetor body held upside down, the float being viewed from the side, adjust the float so that the free end of the float (the end opposite the hinge pin) is ever so slightly higher (just ever so slightly off level) than the other end. And when viewed from the end, make sure it is not cocked.
Thousands of parts in my remaining stock. Not able to list them all. Let me know what you need and I'll look it up for you. Visit my eBay store at:
I got the brp rebuild kits and
I got the brp rebuild kits and it did not come with new orifices. should i get new ones or use the old ones. thanks
