"I have a 2001 Honda 130 with
"I have a 2001 Honda 130 with about 5000 hrs on it. No problem ever until now. After running a short time, which varies between 10 minutes and an hour I get the following combination. Oil light on steady. Overheat light on steady. PGM-FI light on steady. Buzzer beeping about twice a second. Engine seems to still run fine with no drop in power or rpm's. Have replaced water pump (full kit) and thermostat to no avail. Engine does not seem to be running hot, but the top cylinder seems to be quite a bit hotter than the other three. Cannot keep hand on it, but can with the rest of the engine. Engine has always been flushed out with fresh water every time after use since new. All ports look clean as new, but I even flushed cooling system with power washer to make sure. Any ideas anyone. Bugman"
