michigan_brian
"T 9.9 ELRX
Hi guys-
I h
"T 9.9 ELRX
Hi guys-
I have a 1999 Yamaha 4 stk kicker and water is getting in the oil. Quite a bit of water.
The motor runs perfect, the plugs are fine, you would not even know there is an issue with the motor until you look at the oil. No smoking, no running hot, easy starting hot or cold. The motor has always been in freshwater.
I have seen some posts while searching about an issue with the oil pan corroding. I have no problem pulling the powerhead and checking this, I have been around motors for years and I do have the factory service manual for this motor.
I was hoping it was maybe a stuck open t stat and it was just condensation, but there is way too much water in the oil for that. There has to be an internal leak someplace.
Other than doing a compression check, anything else I should be looking for before tearing this apart? I highly doubt its a cylinder head gasket issue but maybe I am not aware of something on this motor...
and the motor is used only for trolling at low speeds if this is of any help. The only time it gets run any faster is during inital warmup of the motor at the start of the day and thats about it...
thanks in advance"
Hi guys-
I h
"T 9.9 ELRX
Hi guys-
thanks in advance"
