23 LTR FORD
h2omike
"Help! My son purchased a 1988
"Help! My son purchased a 1988 harris "float boat" and evidently didn't winterize the 2.3 ltr 4 cyl ford engine correctly. The freeze plugs broke and have been replaced, but when the engine is started, water sprays from the top rear area of the engine above flywheel. Can't tell where exactly until we start dis assembly or pull the engine. Any advise as to where to start will be greatly appreciated.
Thanks, Mike }"
"What about the plug at the re
"What about the plug at the rear, see #2
283017.png"" alt=""
""Boatin Bob",
Thank
""Boatin Bob",
Thanks for the tip. We found the rear freeze plug intact and started the engine. Water is running out of the bell housing where the starter is mounted.
Any guidance will be appreciated.
Thanks, Mike"
"water is coming out of the ba
"water is coming out of the back of the head or block from somewhere.., you'll need to remove parts and look harder."
