Click for Suzuki Manuals, Parts and Model Guides!
Results 1 to 5 of 5
  1. #1
    Default "I do not have a Suzuki dealer
    "I do not have a Suzuki dealer closer than 35 miles from my boat and I do not want to travel that far just to buy two extra quarts of Suzuki 4 cycle oil. I already have one QT of Suzuki SAE 10W-40 (SP-40) and am wandering if I can buy antoher brand of marine 4 cycle oil to combine with what I already have? I know that you can not mix weights of oil but not sure about mixing brands when it comes to outboards. Lastly..could I use a regular 10W-40 form an auto parts store or are marine and automoive oils blended diferently. I have used automitve 10W-30 in Honda 225 HP outboards for a few years and not run into any issues. Suzuki just mentions that any 4 cycle oils used meet SE, SF, SG, SH or SJ under the API system."
  2. #2
    superpole727's Avatar
    superpole727 Guest
    Default Andrew I beleave you answered
    Andrew I beleave you answered your own question. Any 4 cycle Marine oil is fine so long as it meets the specs. Marine oil has some extra corrosion inhibtors and detergents. Each manufacture has there own blend.
  3. #3
    Default I picked up some Chevron 10W 4
    I picked up some Chevron 10W 40 yesterday at Kragen Auto and made sure it met the API requirements for Suzuki. The lable on the back of the qt of oil said it met about 4 API standards but only one was listed in the API "circle" twoards the bottom. Why is this? According to that symbol it only met SM...? Just curious about this.
  4. #4
    Join Date
    May 2009
    Location
    , Washington, USA
    Posts
    10
    Default "Mercury "Quicksilver"
    "Mercury "Quicksilver" 4 stroke is pretty good stuff, give that a try if you've got a merc dealer nearby"
  5. #5
    Default Thanks. The only 10W 40 I cou
    Thanks. The only 10W 40 I could find was West marine's synthetic brand. I ended up using the Chevron I bought.
Similar Threads
  1. 40 HP Yamaha 2 cycle
    By lewicki in forum Yamaha Outboard Forum
    Last Post: 08-11-2010, 02:31 PM
  2. 2003 60 HP Yam 2-cycle
    By dukchaser in forum Yamaha Outboard Forum
    Last Post: 07-29-2010, 12:48 PM
  3. Mercury 115 2 cycle
    By john80 in forum Mercury Mariner Outboard Archive
    Last Post: 08-15-2009, 10:13 AM
  4. 99 2 cycle stalling out
    By 36mainship36 in forum Mercury Mariner Outboard Archive
    Last Post: 08-09-2009, 07:12 PM
  5. 2 cycle engine oil
    By rob_boyd in forum Johnson Evinrude Outboard Archive
    Last Post: 11-18-2008, 08:16 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
