Click for Suzuki Manuals, Parts and Model Guides!
Results 1 to 4 of 4
  1. #1
    Join Date
    May 2008
    Location
    Northwest IL, IL,
    Posts
    44
    Default I was wondering how much oil a
    I was wondering how much oil and what kind of oil this DF 60 suzuki engine takes. And also if anyone know of a site that i could look at to show me some specs on this model of engine.
  2. #2
    superpole727's Avatar
    superpole727 Guest
    Default "Suzukimarine.com for the spec
    "Suzukimarine.com for the specs. Depends on your climate 10-40 in warmer climates 10-30 in colder climates. Start with 4.5 quarts with new filter and chk it, add a little at time to get it in the middle of the stick. Each time you add oil wait about 10 mins for the oil to run to the sump before adding more. Those engines will foul the bottom plug if you run to much oil."
  3. #3
    Default My DF 50 takes 2.5 Qts with a
    My DF 50 takes 2.5 Qts with a filter change. 4.5 qts for a 60 seems overkill. When I bought my boat 2nd hand the owner had the marina (where he purchased the boat) change the oil etc. Those ding dongs overfilled the sump by half a qt. It ran fine. Ended up draining it off. I keep my oil level at the top end of the hash marks.
  4. #4
    superpole727 Guest
    Default 4.5 quarts with a filter is th
    4.5 quarts with a filter is the starting point for a DF60. The DF50 holds less oil 3 cylinder not a 4 cylinder.
Similar Threads
  1. help my df60 is making oil.
    By stindell in forum Suzuki Outboard Forum
    Last Post: 07-10-2010, 07:06 PM
  2. DF60 Injectors
    By gray in forum Suzuki Outboard Archive
    Last Post: 11-20-2008, 12:48 AM
  3. DF60 stalling on low revs
    By jonno in forum Suzuki Outboard Archive
    Last Post: 07-08-2008, 02:29 AM
  4. Df60 rpm problem
    By bitemeboat in forum Suzuki Outboard Archive
    Last Post: 05-26-2008, 02:45 PM
  5. Suzuki DF60
    By minken in forum Suzuki Outboard Archive
    Last Post: 10-16-2007, 11:50 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
