Click for Chrysler parts and manuals!
Results 1 to 2 of 2
  1. #1
    Join Date
    May 2008
    Location
    Posts
    65
    Default "i had to replace my oil coole
    "i had to replace my oil coolers last May 2008. Was checking the fluids today and noticed the starboard transmission fluid looks like pepto bismol which means water.....Again!!!
    What is the best way to remove the old fluid and get the water out? has anyone ever attached some type of filter in line?
    suggestions?"
  2. #2
    Join Date
    Sep 2003
    Location
    New Tripoli, PA, USA!
    Posts
    15,325
    Default "Drain and refill.Drain and re
    "Drain and refill.Drain and refill.Drain and refill.Drain and refill.Drain and refill.Drain and refill.Drain and refill.
    They left out a drain plug, so you have to suck it out with a vacuum deal (like an oil changer set up).
    Jeff"
Similar Threads
  1. Flushing
    By twin 150 in forum Honda Outboard Forum
    Last Post: 12-14-2010, 04:25 AM
  2. Using the Flushing Adaptor Kit
    By the_tassie_devil in forum OMC Sterndrive and Inboard Forum
    Last Post: 06-03-2010, 07:19 AM
  3. Flushing 318
    By opie77 in forum Chrysler Inboard and Sterndrive Forum
    Last Post: 11-03-2009, 03:42 PM
  4. 20 HP flushing
    By desertmariner in forum Honda Outboard Archive
    Last Post: 06-09-2008, 07:28 PM
  5. OMC Flushing after use
    By tmon in forum Johnson Evinrude Outboard Archive
    Last Post: 08-03-2003, 03:39 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
