Results 1 to 9 of 9
    Sep 2008
    Hague, Virginia, USA
    3,818
    Default Folks - just got a call from m
    Folks - just got a call from my dealer. While undergoing 200 hour maintenance (at 240 hours) they found a "significant amount" metal filings in oil. They have no explanation of what has caused this and have a call in to Honda to see what they have to say. Anyone out there experienced this problem? What was cause? What did Honda do about it? This is the last thing in the world I would have expected to see in this engine.
    CHawk 25 DLX
    Sep 2008
    3,818
    Default "Follow up. Dealer called back
    "Follow up. Dealer called back this morning. Honda will replace entire block with new one. If any metal filings found in heads, they'll replace those also. Only down side is it will take "several weeks" to get in parts and do the change over. I'm pretty satisfied with that response both from Honda, and very satisfied with the dealer, Whelen's Marina in Farmham, Virginia."
    CHawk 25 DLX
    Default Did the dealer give you any id
    Did the dealer give you any idea of the cause?
    Honda BF150
    Sep 2008
    3,818
    Default No cause identified yet - will
    No cause identified yet - will likely let me know once they tear down the engine. They won't do that until they receive the replacement block. All of the research I've done indicates this was an exceptionally rare occurance. Even checked the automotive version Honda J35A3. Would like to hear from anyone who has seen this in other Honda V-6 engines.
    CHawk 25 DLX
    Jul 2008
    Tauranga New Zealand
    124
    Default "Bill, make sure they remove t
    "Bill, make sure they remove the camshafts & check the bearing journals for damage from metal filings, & clean out the oil galleries in the heads.
    Bob"
  6. #6
    Sep 2008
    3,818
    Default "Bob - Roger that. Plan to be
    "Bob - Roger that. Plan to be on site when they take the heads off and break them down to inspect them myself. I really want to try to get to the initial cause of the breakdown. If we find it, I'll let you all know."
    CHawk 25 DLX
  7. #7
    Sep 2006
    SF BAY AREA, CALI, USA
    8,649
    Default wow!
    wow!
    HUMAN BUILT = HUMAN FIXED
    CERTIFIED MARINE TECHNICIAN
    WWW.JUSTINTIMEMARINE.COM
  8. #8
    Sep 2008
    3,818
    Default "This post is a follow up on m
    "This post is a follow up on metal filings in the oil of my BF 225.
    The block was replaced by the dealer and I'm breaking it in now. However, this is apparently not a rare occurance as I originally thought and posted to this forum. As I've dug into this, it appears to be a VERY SIGNIFICANT ISSUE with some number of these BF 200's and 225's, especially for motors produced over the last two years or so. Honda is apparently experiencing some sort of production problem with these engines, but I cannot determine what it is, or the incidence level.
    My advice to all BF 200 and 225 owners is to very carefully check your engine oil for metal filings on a regular basis. Whenever you check the oil level, shine a flashlight down in the opening and look for any "sparkles" which will indicate an abnormal amount of metal in the oil. Stick a magnet probe down into the oil and check it carefully. When changing the oil check the magnetic plug carefully, and run a probe magnet around in the drained oil. Any metal that is larger than talcum powder may indicate a problem. Also, when you replace the oil filter, let it drain thoroughly into a separate container, and check that for metal filings also.
    Hope some of the Honda masters on this forum will also jump in with their observations and advice."
    CHawk 25 DLX
  9. #9
    Sep 2006
    8,649
    Default only thing i have been seeing
    only thing i have been seeing is camshaft thrust washers blowing up!!
    also every oil change i have seen it comes out milky at the end
  1. metal tag on top of outdrive
    By sticky in forum Volvo Penta Gas Engine Forum
    Last Post: 04-27-2010, 10:33 AM
  2. Metal shavings removal 1993 7.4 L
    By tnsailorguy in forum Mercruiser Sterndrive Forum
    Last Post: 02-18-2010, 12:17 PM
  3. NS5B metal gas tank
    By carl_v in forum Nissan Tohatsu Outboard Forum
    Last Post: 09-20-2009, 09:11 PM
  4. Whats best metal for an oil pan in a chevy
    By leeroy in forum Volvo Penta Gas Archive
    Last Post: 02-28-2008, 02:58 PM
  5. Metal in oil
    By sae267839 in forum OMC Sterndrive and Inboard Archive
    Last Post: 04-06-2006, 12:12 AM
