Click for Suzuki Manuals, Parts and Model Guides!
Results 1 to 3 of 3
  1. #1
    Default "i found a lower unit for my s
    "i found a lower unit for my suzuki 95 dt140. however it is a 87. are these two interchangeable??? please help as I really miss my boat..."
  2. #2
    superpole727's Avatar
    superpole727 Guest
    Default "1985 were different shorter s
    "1985 were different shorter shaft. 1987 should work, measure the length of the DS from the top of the shaft to upper brg hsg located under water pump. Gear ratio should be the same."
  3. #3
    Join Date
    Feb 2009
    Location
    Conway, SC,
    Posts
    78
    Default "I believe Robert is right but
    "I believe Robert is right but if for some reason the '87 lower unit does not work out give me a shout, I have a reworked 20" shaft LU off of a '98 DT140."
Similar Threads
  1. Lower unit swap
    By paulj in forum Johnson Evinrude Outboard Archive
    Last Post: 03-30-2008, 03:18 PM
  2. Lower Unit swap
    By jameskb2 in forum Johnson Evinrude Outboard Archive
    Last Post: 09-09-2007, 10:45 PM
  3. 77lower unit swap with 78 lower unit
    By ed270electric in forum Johnson Evinrude Outboard Archive
    Last Post: 08-31-2007, 11:10 PM
  4. Lower unit swap
    By chazman35 in forum Johnson Evinrude Outboard Archive
    Last Post: 05-12-2007, 12:16 AM
  5. Lower unit swap
    By Steve Strawn in forum Johnson Evinrude Outboard Archive
    Last Post: 05-19-2006, 05:49 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
