"Had boat out last weekend aft
"Had boat out last weekend after having fuel pump replaced by Sea Ray Dealer because the engine had been hydro-locked with fuel. Sea Ray checked everything out and said compression was good. Had boat out all weekend when on the way back to dock the engine just cut. (Doing about 35 mph.) Restarted engine and made it back to dock. Decided to play around with it a little and engine cut again when at full throttle. Started boat and took out of water. Took it back to Sea Ray who now tells me that on a leak down test, cylinder 3 is losing about 40% compression and I need a new motor. Boat was running great before and after engine had cut. Is it possible that a motor with one bad cylinder could run that well? They are telling me I need a new motor. Is there any rebuild options that are available. Boat still starts and will run until it gets to full throttle. Any Advice?"
