MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 9 of 9
  1. #1
    Default "Looking to get a 1995 mercury
    "Looking to get a 1995 mercury 115, any issues to know about with this engine?"
  2. #2
    Join Date
    Jul 2006
    Location
    Cayce, SC, USA
    Posts
    45
    Default "I just got a '95 125. Fro
    "I just got a '95 125. From what I have read from these gentlemen, it's a called a 2 + 2. At idle it runs on the top to cylinders then at around 1800 RPM it kicks in the lower two. Besides that I don't know much more. I'm just now getting mine to where itís running like new again. Good luck and this forum has so much information about your motor. Just search "115" in the Mercury discussion and you will have your hands full."
  3. #3
    Join Date
    May 2007
    Location
    Inverary, Ontario, Canada - The Great White North Eh!
    Posts
    9,114
    Default "The 115 was very popular and
    "The 115 was very popular and a decent engine with no real chronic issues. It stayed in production until 2005 and is still well supported by Merc (parts/service).
    If the compression is good, it runs decently and is in fair cosmetic shape I would expect that vintage to sell for between 1500 (salt run motor) and maybe 2500 (top end if in excellent shape).
    Personally, I would have no issue hangin' a 95, 115 off the back of my boat."
    Graham
    A "professional" is someone who gets paid for their work - it doesn't necessarily mean they are good at it :)
  4. #4
    Join Date
    Sep 2003
    Location
    New Tripoli, PA, USA!
    Posts
    15,325
    Default "..."Personally, I would h
    "..."Personally, I would have no issue hangin' a 95, 115 off the back of my boat."
    Hopefully, not the boat you did those small motors tests on!
    Jeff"
  5. #5
    Join Date
    Sep 2007
    Location
    Posts
    1,068
    Default Chronic Issues: Oil line tubi
    Chronic Issues:
    Oil line tubing.
    Oil tank/cap leaking.
    Oil tank sensor/alarm.
    Voltage Regulator/stator burn out. (fire hazard)
    L/U stuck/salted on the nose stud. Hard to remove.
    Poppit valve/chronic overheat (weed infested waters)
  6. #6
    Join Date
    Oct 2007
    Location
    , ny, us
    Posts
    1,038
    Default "Bandit certainly knows these
    "Bandit certainly knows these motors...the problems he pointed out are common but with proper maintenance, it is a great motor. There is a slight bit of hesitation at 1800RPM when the motor goes from 2 to 4 cylinders(especially on decelleration... 4 to 2) but if adjusted correctly, it isn't too much of an annoyance. Change those oil lines immediately...mine were brittle and ready to crumble. Have it checked out by a Merc mechanic before purchase...money well spent!"
  7. #7
    Join Date
    May 2007
    Location
    Posts
    9,114
    Default "What, I can't put a 115 o
    "What, I can't put a 115 on my 220lb 14 foot aluminum? [img][/img]
    And a little too small for my 25 footer (but a pair would be nice) - ok, would hang it on the back of a boat that it was suited to - if I owned one in that class..."
    Graham
  8. #8
    Join Date
    Jun 2008
    Location
    , nj, usa
    Posts
    51
    Default I know of two fires from the s
    I know of two fires from the stator with this engine.
  9. #9
    Join Date
    Apr 2008
    Location
    Johannesburg, Gauteng, South Africa
    Posts
    367
    Default "Hi! Had the 1997 2+2
    "Hi!
    Had the 1997 2+2. Ran great, similar issues with volt regulator and alarms. Seemed that the alarm unit was faulty...
    Good idea to run a 100:1 mix in the tank for peace of mind...
    Ignition switches also known to give hassles.
    Otherwise good motors judging by the amount seen on the ponds around here.
    Enjoy!"
Similar Threads
  1. 1995 mercury 225 hp
    By Sharkbitten in forum Mercury Mariner Outboard Forum
    Last Post: 04-13-2010, 11:45 AM
  2. 1995 Mercury 2 stroke
    By bigtimber in forum Mercury Mariner Outboard Archive
    Last Post: 08-24-2009, 12:50 PM
  3. 1995 mercury 150 xr6
    By bubb7a in forum Mercury Mariner Outboard Archive
    Last Post: 07-01-2009, 04:26 PM
  4. 1995 Mercury 150 XRI EFI
    By Brian Albri in forum Mercury Mariner Outboard Archive
    Last Post: 03-22-2007, 01:13 PM
  5. 1995 mercury 115
    By gabriel copello in forum Mercury Mariner Outboard Archive
    Last Post: 12-31-1969, 08:00 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
