Click for Chrysler parts and manuals!
Results 1 to 3 of 3
  1. #1
    Join Date
    Nov 2008
    Location
    Fond du lac , WI, USA
    Posts
    11
    Default "1969 lm318 overheats, raw wat
    "1969 lm318 overheats, raw water cooled, sherwood D-60 pump, Thermostat removed no changes. Once warmed up gauge occaisonally dips slowly down to to 140 then slowly creeps back up to 180 or slightly higher. Please help!
    Steve"
  2. #2
    Join Date
    Nov 2008
    Location
    Posts
    11
    Default "What temperature should the g
    "What temperature should the guage read?
    Should it stay constant while holding the same rpm?
    Someone else suggested capping the hose that goes from the thermostat to the supply side of the pump, can the engine be run like this?"
  3. #3
    Join Date
    Sep 2003
    Location
    New Tripoli, PA, USA!
    Posts
    15,556
    Default "..."Someone else suggeste
    "..."Someone else suggested capping the hose that goes from the thermostat to the supply side of the pump, can the engine be run like this?"
    If that's a dual pocket pump, no! The water coming out of the pump has to go somewhere. Unlike normal circulating pump arrangements, this is a positive pressure pump that can not be "backed up" against a closed off flow.
    A few suggestions:
    1. IF that is a dual pocket pump setup, be sure the line running back to the pump is clear.
    2. Check for any air leaks going to the pump, like from a strainer cover, leaking sea cock valve, loose hose connection, etc. ANY air coming will cause all kinds of problems.
    Jeff"
Similar Threads
  1. LM318 water temp alarm
    By pietro in forum Chrysler Inboard and Sterndrive Forum
    Last Post: 09-14-2010, 07:26 AM
  2. LM318 Raw Water Plumbing
    By Jeff H in forum Chrysler Inboard and Sterndrive Forum
    Last Post: 04-02-2010, 02:37 PM
  3. Runs at idle with 4 plug wires removed 318
    By greasemonkey in forum Chrysler Inboard and Sterndrive Forum
    Last Post: 08-27-2009, 01:42 PM
  4. 1994 70hp Johnson removed oil injectionfuel pump now what
    By drewpolk in forum Johnson Evinrude Outboard Archive
    Last Post: 09-01-2008, 10:16 PM
  5. Seacock for Raw Water Inlet LM318 single
    By randyp in forum Chrysler Inboard and Sterndrive Archive
    Last Post: 10-18-2006, 03:46 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
