OMC tilttrim relay
chip1955
I was trying to get my boat re
I was trying to get my boat ready to hit the water and am only getting 'clicks' from the
tilt/trim pump area. I hot wired the motor and found out that it works so am assuming that it is the relay/circuit breaker unit. I took it off and it looks like a sealed unit. 2 questions:
does it seem likely that this component is bad? and if so where is best place to find one?
thanks.
Chip
"more likely bad connections.
"more likely bad connections. If you know how to do voltage drops, you can pinpoint the resistance. Or...you can skip the pinpointing and just file both sides of each ring terminal shiny, and also the terminal side of each nut that threads onto the posts. Follow back towards batt. and clean each connection.
If you need a relay, get one right here at marineengine.com to support this board."
