Click for Chrysler parts and manuals!
Results 1 to 7 of 7
  1. #1
    Join Date
    Apr 2008
    Location
    Keuka Lake, New York, USA
    Posts
    61
    Default "Chrysler M440 engine. It had
    "Chrysler M440 engine. It had a blown head gasket last fall, which is now fixed (& the oil was changed). It runs fine now, but I still see some water in the oil. Is it common that it takes a few oil changes to get all the water out, after an event like a blown head gasket?"
  2. #2
    Join Date
    Sep 2003
    Location
    New Tripoli, PA, USA!
    Posts
    15,552
    Default If the motor was hot tanked an
    If the motor was hot tanked and cleaned the moisture should be gone.
    Jeff
  3. #3
    Join Date
    Apr 2008
    Location
    Posts
    61
    Default The motor didn't come out
    The motor didn't come out of the boat. Just a head gasket & valve job.
  4. #4
    Join Date
    Sep 2003
    Location
    Posts
    15,552
    Default Okay. Then you WILL need to he
    Okay. Then you WILL need to heat her up good and do an oil change or two.
    Got 'em crossed for you!
    Jeff
  5. #5
    Join Date
    Sep 2008
    Location
    New York, NY, USA
    Posts
    71
    Default "I just went through this exac
    "I just went through this exact issue. Resolved it last weekend by doing 3 back to back oil changes. Did the first two with thin weight oil (cheaper stuff too) and then the final oil change, I used good stuff. Also, I went through two cheap Fram filters during the process and intend on using a better one when I'm ready to run next.
    Oil is clear for me now."
  6. #6
    Join Date
    Sep 2003
    Location
    Posts
    15,552
    Default Great! Jeff
    Great!
    Jeff
  7. #7
    Join Date
    Jul 2006
    Location
    Redmond, WA, USA
    Posts
    216
    Default You need to run it hard enough
    You need to run it hard enough and long enough to get the oil up to about 200 degrees to evaporate the moisture. 30 minutes at 3000 rpm should do it.
    Dan
Similar Threads
  1. Not sure how to proceed. Blown head gasket, head or worse...
    By Philster in forum Mercruiser Sterndrive Forum
    Last Post: 08-17-2010, 05:08 PM
  2. Oil pressure and a blown head gasket
    By srdancer90 in forum Mercruiser Sterndrive Archive
    Last Post: 08-26-2008, 09:12 PM
  3. Blown Head Gasket
    By ldell in forum OMC Sterndrive and Inboard Archive
    Last Post: 07-07-2008, 10:45 PM
  4. Blown head gasket
    By Brandon Wojcik in forum Volvo Penta Gas Archive
    Last Post: 05-17-2007, 11:40 AM
  5. Blown head gasket
    By Will C. in forum OMC Sterndrive and Inboard Archive
    Last Post: 04-27-2006, 05:42 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
