"I had my carb rebuilt this wi
"I had my carb rebuilt this winter and put them back on the boat this spring. They fired right up when I put the boat in the water last weekend. My slip is about 25 minutes through a no wake channel away from where I was put in. the engines both ran flawlessly all the way to my slip. No missing, no spittin or sputterin. I put the boat in the slip and went to breakfast. When I came back I went to start the starboard engine and it wouldn't start. Technically, I guess it is starting for a brief second but then stalls. The port engine starts and runs fine. The starboard engine will fire and start long enough to disengage the bendix on the starter but then stall regardless to whether or not I pump the throttle. I suspected my fuel pump had quit. So I took the flame arrestor off and held the butterfly open on the carb and pump the throttle and I could see gas injecting into the carb. So, I guess the fuel pump is still working. The ignitions were changed over to electronic ignitions before I bought the boat. I have a hard time believing it is plugs and wires because I change those last spring and when I brought the boat to the slip it ran great. Anybody got any ideas????"
