Click for Suzuki Manuals, Parts and Model Guides!
Results 1 to 8 of 8
    Dec 2008
    Parker, Arizona, USA
    66
    Default "I am installing this pump on
    "I am installing this pump on my boat.
    http://cgi.ebay.com/ebaymotors/ws/eB...m=220400825043
    Should I keep the primer ball? The seller is not sure if the pump will "draw" from the tank and pump it uphill. My plan is to mount it on the inside of my transom about 3"-4" above the tank. It will need to push the fuel up another 6"-8" to the top carb on my motor."
    Sep 2006
    SF BAY AREA, CALI, USA
    8,649
    Default why??
    why??
    HUMAN BUILT = HUMAN FIXED
    CERTIFIED MARINE TECHNICIAN
    WWW.JUSTINTIMEMARINE.COM
    Dec 2008
    66
    Default "Suzuki fuel pump $113+ Sh
    "Suzuki fuel pump $113+ Shipping. Replacement diaphragm kits every six months $20+ Shipping. Having a pump that is not a pain in the ass PRICELESS.
    The factory pump has been a total pain in my ass since I got this motor last year. The diaphragm has failed twice, now the freaking check valves are shot.
    I have this exact electric pump on my sand rail, 3 years and still not a lick of trouble.
    Last but not least, BECAUSE I FUKING CAN!!!"
    superpole727's Avatar
    superpole727 Guest
    Default "Your the best Joe <[img]"http
    "Your the best Joe . I couldn&#39;t have said it better myself. You should keep the primer bulb though."
    Sep 2006
    8,649
    Default look at USCG regs get back
    look at USCG regs
    get back 2 me
  6. #6
    Dec 2008
    66
    Default "This was all I could find on
    "This was all I could find on the USCG site.
    &#34;Each electrically operated fuel
    pump must not operate except when
    the engine is operating or when the engine
    is started.&#34;
    My pump gets power from the same wire that powers the overheat switch. It is hot only when the key is on. I also tapped the green wire from the kill switch to ground the pump as well.
    I tested it, when the kill switch is pulled, the motor AND pump shut down."
  7. #7
    Sep 2006
    8,649
    Default what motor is this on?
  8. #8
    Dec 2008
    66
    Default "It is on my 1980 DT65. The pu
    "It is on my 1980 DT65. The pump is supplying plenty of fuel. The motor runs real good except for one flat spot around 1200-1300 RPM.
    It surges on accel or decel at that rpm. If I just tap the throttle up or pull back ever so slightly the surge goes away. The base idle&#40;800rpm&#41; timing is set at 3&#42; ATDC like the manual calls for.
    When I watch the throttle linkage, the surge is occurring just before the linkage starts advancing the timing."
  1. Electric fuel pump
    By xspy99 in forum Johnson Evinrude Outboard Archive
    Last Post: 07-06-2009, 02:17 AM
  2. Electric fuel pump
    By mikeinflorida in forum Mercruiser Sterndrive Archive
    Last Post: 05-21-2009, 08:53 PM
  3. Electric Fuel Pump to Reduce Fuel Rollback
    By knuckle47 in forum Crusader Marine Archive
    Last Post: 05-07-2009, 11:39 PM
  4. Electric Fuel Pump
    By dominator in forum Johnson Evinrude Outboard Archive
    Last Post: 11-16-2008, 07:32 AM
  5. Electric fuel pump
    By dcso408 in forum Johnson Evinrude Outboard Archive
    Last Post: 07-21-2007, 05:40 PM
